You may be aware that the RODE Wireless ME microphone system is renowned among vloggers, bloggers, content creators and influencers globally. It allows you to integrate wireless and hands-free audio seamlessly into your productions.
Chances are you have purchased RODE Wireless ME and necessitate to connect it to your iPhone.
Here, we’ll meticulously guide you on how to perform this procedure easily. We’ll provide additional tips to help you get the most out of this easy-to-use and streamlined microphone system.
Lastly, we’ll address your frequently asked inquiries regarding the RODE Wireless ME.
Let’s begin.
Procedure to Connect RODE Wireless ME to iPhone
Before proceeding with the given procedure, let’s start by providing some essential information about the RODE Wireless ME.
Getting Started
As you can see, the RODE Wireless ME is a supercompact wireless microphone system. It allows for recording professional audio for your videos untroubled.
The RODE Wireless ME comprises two distinct components. One is called the receiver. On its backside, it is written as RX. The other component encompasses either one or two transmitters, depending on whether you have a Single or Dual Set. On its backside, it is written as TX.
The function of the transmitter is to pick up audio either via its integrated microphone or an external mic connected to its 3.5mm input. It then wirelessly transmits that audio to the receiver.
The receiver then sends the audio via its 3.5mm output or USB-C to your device. That can encompass your camera, computer, smartphone or other audio device.
The Procedure
- In the commencing step, you’ll power on the receiver and the transmitter. At the bottom, there’s a power button on both. Press and hold the power button on both the receiver and the transmitter simultaneously for 3 seconds.
- Wait as the LED light turns on both components. That means both the receiver and transmitter are powered on. Moreover, the connectivity indicator LED on the receiver will flash amber shortly. It will turn to solid amber. That’s indicative that the receiver is now paired together with the transmitter.
- Next, connect the receiver to your iPhone via the SC21 USB-C to Lightning cable included with RODE Wireless ME. Plug one end of the cable into the receiver and the other end into the iPhone.
- On your iPhone device, navigate to the App Store. Search for an app named RODE Central Mobile. Download and install that app.
- Open the RODE Central Mobile app. It will show both RX and TX. That’s indicative of their pairing and connectivity with your iPhone. The app further displays the battery percentage for both the transmitter and receiver. You can observe that the pairing icon is green. The microphone system is now ready to use.
- The next step is testing the connectivity. For that, open your iPhone’s camera app and record a video. Then, tap the transmitter to test the microphone.
- Lastly, play the recording.
Extended Tips
You now know how to connect and use the RODE Wireless ME to your iPhone. After that, here are added tips that will aid you in getting the most out of this ultra-compact microphone system:
- The receiver flaunts a clip at its back side. You can easily attach it to your iPhone’s backside via that. On the other hand, the transmitter can be employed as a wireless microphone for recordings.
- Both the RODE Wireless ME’s receiver and transmitter have a clip. It can further be used to attach the units to clothing or other items. The clip can be slotted into the camera or an identical device’s cold shoe mount. That secures it in place safely.
- You may have an older iPhone model. In that case, you may need cables like the Apple Lightning to 3.5 mm adapter and the RODE SC7 cable.
- You can also utilize the MagClip GO, which is available separately. It allows you to attach the Wireless ME receiver directly to your magnet-compatible (or, more specifically, MagSafe-equipped) iPhones. It’s built-in to the newer iPhone models (i.e., iPhone 12 onwards and up to the iPhone 16 series).
We hope you now grasped the easy way to connect RODE Wireless ME to your iPhone. You also gained valuable insights into tips for using the wireless microphone system to its full potential.
To conclude, connecting and using the RODE Wireless ME is quick, easy and straightforward. You may be an experienced vlogger or one just starting with your production. In each case, you’ll find the system very convenient and practical.
What are the salient features of the RODE Wireless ME?
Despite its pocket-sized, iconic form factor, the RODE Wireless ME is laden with features. The prominent of them are:
- Ultra-compact and easily usable wireless microphone system
- Intelligent GainAssist Technology to automatically regulate audio levels for crystal-clear sound in any app
- Series IV 2.4 GHz digital transmission over 100m range (with 128-bit encryption) for exceptionally stable and clear recording
- Built-in rechargeable battery (lithium-ion)-up to 7 hours life
- Works flawlessly with computers, cameras, smartphones (iPhones and Android phones)
- Compatibility with RODE video and audio apps like RODE Capture and RODE Reporter
- Availability in single or dual sets (with one or two transmitters)
- All required cables included: no added gear needed
What are the varied applications of RODE Wireless ME?
The following are the varied applications of the RODE Wireless ME wireless microphone system:
- Blogging and vlogging: The Wireless ME is ideally suited for bloggers and vloggers who require high-quality, crystal-clear audio for their videos. That’s whether they’re shooting on a mobile device, such as an iPhone or a camera.
- Tutorials and presentations: It’s an ideal option for recording presentations and tutorials where crystal clear audio is pivotal.
- Documentaries and interviews: The Wireless ME’s built-in microphones on both receiver and transmitter let you seamlessly capture audio from both sides. That makes it highly fitting for documentaries and interviews.
- Podcast and live streaming: In conjunction with the RODE Connect software, the Wireless ME is usable for podcasting and live streaming.
- Filmmaking: The RODE Wireless ME can also be used to capture professional-quality audio throughout filmmaking projects.
What is RODE specialized in making?
As you see, RODE is an audio technology company headquartered in Sydney, Australia. That’s where most of its products are fabricated.
Briefly, RODE is specialized in fabricating the following:
- Incredible array of microphones, e.g., Wireless ME and Wireless Micro
- Audio interfaces and mixers, e.g., Streamer X
- Headphones, e.g., NTH-50 (Professional On-Ear Headphones)
- Software for varied production and recording appliances like RODE Capture, RODE Connect and RODE Reporter
- Varied Accessories, e.g., MagClip GO and VESA Mount
- Range of Equipment kits like Ultimate Podcast Kit and Street Interview Kit
日本語
Português
