How to Save Audio as VBR MP3 in Audacity: The Best Quality Settings
By Hollyland | March 4, 2026
If you are figuring out how to save audio as VBR MP3 in Audacity, you are likely trying to solve a common problem: keeping your file sizes small without ruining the sound quality.
When you export a project, you face a choice between CBR (Constant Bit Rate) and VBR (Variable Bit Rate). For decades, CBR was the standard, applying the exact same amount of data to every second of audio—whether it was complex music or total silence. It’s reliable, but inefficient.
VBR is the smarter, modern alternative. It analyzes your audio in real-time. During complex moments, it boosts the quality. During silence or simple speech, it saves data. The result? A professional-sounding file that takes up significantly less space on your hard drive.
Here is how to set it up correctly, choose the right quality slider, and troubleshoot common export errors.
Step-by-Step: How to Export as VBR MP3 in Audacity
VBR is not the default setting in Audacity, so you have to dig into the menu to find it. Follow this workflow to ensure your audio is compressed efficiently.
  1. Open your project in Audacity.
  1. Go to the top menu bar and select File > Export > Export as MP3 or File > Export Audio on Mac.
  1. Look for the Format Options section at the bottom of the export window.
  2. Change the Bit Rate Mode from “Preset” or “Constant” to Variable.
  1. Select your Quality level from the dropdown menu (e.g., Standard, Extreme, or Insane).
  1. Click Save (or Export).
Quick Note on Encoders: If you haven’t used Audacity in years, you might remember needing to download a separate file called lame_enc.dll. You don’t need to do that anymore. Modern versions of Audacity come with the MP3 encoder built-in, so these steps will work immediately.
Understanding Audacity’s VBR Quality Settings (0-9)
Once you switch to Variable mode, you will see a “Quality” dropdown menu with options ranging from 0 to 9.
This scale confuses many beginners because it works backward compared to most grading systems:
  • 0 is the Best Quality (Largest file size).
  • 9 is the Lowest Quality (Smallest file size).
These numbers control how aggressively the encoder compresses your audio. Lower numbers (0-2) preserve more detail, while higher numbers (5-9) cut more data to save space, which can result in a “swirly” or underwater sound.
Comparison of VBR Quality Settings
Use this table to pick the right setting for your specific project.
Quality SettingPreset NameApprox. BitrateBest Use Case
0Best Quality220–260 kbpsMusic, Sound Design, Archival Audio
1Extreme200–250 kbpsHigh-Fidelity Music Streaming
2Standard170–210 kbpsPodcasts, Interviews, YouTube Voiceovers
3–4Medium145–185 kbpsLectures, Voice Memos, Zoom Recordings
5–9Low45–130 kbpsRough Drafts, Speech-to-Text Reference
Which Setting Should You Choose?
  • For Podcasters (Recommended: Quality 2):
    Select Quality 2 (Standard). This is the industry sweet spot. It sounds identical to the source for spoken word but keeps the file size small enough for quick mobile downloads. It hovers around 192kbps, which works perfectly for Apple Podcasts and Spotify.
  • For Musicians (Recommended: Quality 0):
    Select Quality 0 (Best). If your mix has deep bass, crisp highs, and wide stereo effects, you need the extra data. This setting allows the bitrate to spike up to 320kbps during intense sections so you don’t lose any frequency information.
Pro Tip: The Source Audio Matters More Than the Export
While VBR settings are important, they follow the golden rule of audio engineering: Garbage in, garbage out.
MP3 is a “lossy” format. To reduce file size, the software throws away data it thinks you won’t hear. If your original recording has background hiss, clipping, or distortion, the VBR encoder cannot fix it. In fact, compressing a bad recording often makes the digital artifacts sound even harsher.
To get the most out of VBR, you need a clean, high-fidelity source file.
Why Hardware Makes the Difference
If you record vocals or podcasts, your microphone sets the ceiling for your quality. We recommend the Hollyland LARK MAX 2 for creators who want bulletproof source audio.
Here is why the LARK MAX 2 fits this workflow:
  • 32-bit Float Recording: This is a massive advantage for post-production. 32-bit float captures such a wide dynamic range that it is virtually impossible to distort your audio, even if you scream into the mic. When you import this file into Audacity, you have perfect data to work with.
  • Studio Quality Foundation: It records in 48kHz/24-bit. When you eventually compress this down to a VBR MP3, you are starting from studio-grade clarity rather than trying to salvage a muddy recording.
The Bottom Line: You can dial in the perfect VBR settings, but they only work if the input is clean. Recording with a tool like the LARK MAX 2 ensures that when you finally hit “Export,” you are preserving quality, not compressing noise.
VBR vs. CBR: When Should You Use Which?
Even though VBR is more efficient, there are still specific scenarios where the older CBR format is necessary. Here is a quick guide to help you decide.
Choose VBR (Variable Bit Rate) If:
  • File Size Matters: You want to save disk space or bandwidth.
  • You Are Recording Speech: Podcasts and interviews have lots of natural pauses. VBR compresses these silent gaps aggressively, making the file much smaller than a CBR version.
  • Your Audience Uses Modern Devices: Smartphones, computers, and streaming apps handle VBR perfectly.
Choose CBR (Constant Bit Rate) If:
  • You Need Retro Compatibility: Some very old car stereos or legacy hardware players cannot read VBR headers correctly. This can cause the track to skip or the “Time Remaining” display to glitch.
  • You Are Live Streaming: Internet radio often requires a steady flow of data to prevent buffering. CBR ensures the data rate never spikes above the listener’s bandwidth limits.
  • Precise Timing is Required: In some broadcast workflows, CBR is preferred to ensure the file duration remains mathematically exact down to the millisecond.
Troubleshooting Common Export Issues
Sometimes Audacity throws an error or gives you a file that doesn’t look right. Here is how to fix the three most common problems.
Error: “lame_enc.dll” is Missing
If you see this error, you are likely using a very old version of Audacity. Years ago, you had to install the MP3 encoder separately due to licensing.
The Fix:
Do not download strange DLL files from third-party sites. Simply update Audacity to the latest version. The developers now include the LAME encoder by default, so an update will resolve this immediately.
Metadata Tags Not Saving
You typed in the Artist Name and Track Title, but the final file shows up blank in your media player. This often happens if the metadata window is disabled.
The Fix:
  1. Click on “Edit Metadata”, enter your track details and click OK.
Stereo Tracks Merging to Mono
It is frustrating to record a rich stereo podcast, only to have the final MP3 play back in flat mono.
The Fix:
Check the Channels section in the Export Audio window again.
  1. Make sure Stereo is selected.
Is VBR better than 320kbps CBR?
For efficiency, yes. If you select VBR Quality 0 (Insane), you get audio that sounds identical to 320kbps CBR, but the file size will be smaller because it saves data during silent or simple sections. Use 320kbps CBR only if you need to play the file on legacy hardware.
Does Audacity reduce audio quality when exporting to MP3?
Yes, but that is because MP3 is a “lossy” format. It discards data to save space. Audacity uses the LAME encoder to minimize this loss, but it’s unavoidable with MP3s. For the highest fidelity, keep your project in a lossless format (like WAV) until the very last step.
What is the best MP3 quality setting for podcasts?
VBR Quality 2 (Standard) is the best choice for most podcasts. It averages around 192 kbps, offering a great balance between clear voice quality and quick download speeds for your listeners.
Exporting with Variable Bit Rate (VBR) in Audacity is the smartest way to balance storage and sound. By switching away from the default settings, you ensure you aren’t wasting bandwidth on silence.
However, remember that compression is just the final polish. Even the “Best” export setting cannot fix a distorted recording. To guarantee your VBR MP3s sound professional, start with a device that captures clean audio from the source, like the Hollyland LARK MAX 2.
When you feed a high-quality file into Audacity, your final export will sound exactly the way you intended—crisp, clear, and ready for the world to hear.
