New Product Coming
DAYS
HRS
MINS
SECS
Power
December 6, 2023
1. What kinds of batteries are supported for Mars 400s Pro II?
Use the SONY NP-F series battery to power the device such as F970, F750, and F550. You can also use the V-mount battery when you have a D-Tap to DC cable.
2. Does it support the use of a USB-C charger to power the device?
The device supports power supply through a standard 5V 2A USB-C charger.
Note: It does not support power supply through a fast-charging USB-C charger. It is not recommended to use a power bank to charge because the charging current and voltage of the power bank drop rapidly. The device’s charging current and voltage needs to be over 5V 2A.
3. Does it support the use of a DC adapter to power the device?
The device supports power supply through the DC adapter with a voltage input from 6-16V.
RELATED POSTS
