New Product Coming
DAYS
HRS
MINS
SECS
Power Solutions & Usage time
March 27, 2023
OVERVIEWS: Multiple power solutions can provide more flexible choices to the customer, and ensure the smooth running of activities, the article below will show you how to power our device and how long it can be used.
POWER SOLUTIONS:
  • NP-F Battery
  • G-Mount/V-Mount Battery
  • 12V DC Adapter
Note:
  • The G-Mount/V-Mount battery plate can be exchanged
  • you can power the device in three ways at the same time, the one with higher voltage will give priority to the power supply
  • The device does not support to charger the battery
USAGE TIME:
Base Station:
NP-F Battery:     NP-F550        6h
                          NP-F750        12h
                          NP-F970        18h
G-Mount/V-Mount Battery:  Over 50h
Intercom Headset:
Removable Battery:   10h
Charging Base:
You can charge 8 batteries at the same time via the charging base, charging time is 2.5h
RELATED POSTS
