Solutions to Why TikTok Auto-Scroll Not Showing Up: A Simple Guide!
By Hollyland | September 3, 2024
Are you a TikTok user who is unable to access the auto-scroll feature? Don’t worry, you’re not the only one who has encountered the same problem. There could be various reasons, including device unpredictability, regional variances, or technical issues.
In this article, we will go over the details of this feature and suggest solutions so that you may use it on your TikTok account. Let’s get started right now.
What is TikTok Auto Scroll Feature?
The auto-scroll feature is the new feature designed to automatically swipe up on the screen. This feature allows you to enjoy the videos hands-free while they play smoothly one after the other. The only drawback is that this feature is not available for everyone, as it is still in the testing phase. If you’ve access to this feature, here’s how you can turn it on and enjoy it.
How to Turn On Auto Scroll Feature in TikTok
As the auto-scroll feature is new, it may be possible that many users will have difficulty using it. If you are one of them, then you can go through the steps described below to learn how it works.
Step 1: Open your TikTok app and navigate to the Home >> For You page.
tiktok home page
Step 2: Here, press and hold the video, and the ribbon menu will open. In this menu, you will see the Auto scroll option. To activate this, click on it.
tiktok auto scroll
Step 3: In case you want to turn off the auto scroll, repeat the previous steps and click the Manual scroll option.
tiktok manual scroll
That’s it! However, if you have noticed that the auto-scroll feature is not showing up on your TikTok, try out simple solutions.
Possible Reasons Why TikTok Auto Scroll Not Showing Up
This feature is not available to everyone, and some who once had it may find that it has disappeared. Here are some common reasons why the auto-scroll feature is not available on your TikTok:
a. Feature Unavailable To All TikTok Accounts
Gradual rollout: TikTok often releases new features through a gradual rollout process, meaning not all users enjoy the feature at the same time. Some users might gain access to the auto-scroll feature early on, while others may need to wait until it fully rolls out.
Device variability: It’s possible that devices with outdated operating systems or older hardware won’t work with the auto-scroll feature. Because of this, some devices might be unable to see the functionality even if it is present.
Regional difference: TikTok sometimes limits new features to particular geographical areas during the testing or early release stages. Until TikTok widens its rollout, the auto-scroll feature won’t be accessible on your account if you live in an area where it hasn’t been implemented.
b. Beta Testing
TikTok frequently uses a small user base for beta testing before releasing new features to the general public. This allows TikTok to find bugs, get user input, and improve. This is why it is unavailable to some users.
c. Technical Glitches
Technical problems may sometimes cause the auto-scroll feature to appear or stop working as intended. Common glitches, such as app bugs, cache issues, and connectivity problems, could be the reasons.
Possible Solutions to Bring Auto Scroll on TikTok
To access the auto-scroll feature on your TikTok account, you can try these solutions.
1. Update Your TikTok App
The most common reason “auto scroll” is not showing up on your device is that your app is outdated. Because new features are generally rolled out in updated apps. Here’s how you can update the TikTok app.
Android
Android users can easily update their TikTok app with the following step-by-step guide.
Step 1: Go to the Play Store and open it.
navigate to play store
Step 2: Type TikTok in the search bar and press the Search button.
type for search
Step 3: Click on the Update button.
update tiktok
 iPhone
If you are an iPhone user, go through the below steps:
Step 1: Navigate to the App Store and open it.
 navigate to app store
Step 2: Enter TikTok in the search bar and click the Search button.
enter text
Step 3: Click on the Update button and open the TikTok app once the update is completed.
update tik tok app
2. Try Changing Region through a VPN
If the TikTok auto-scroll feature isn’t available where you live, one possible solution is to use a VPN (virtual private network) to alter your location. This can assist you in gaining access to features that could be limited to particular areas. Here’s how you can activate the auto-scroll function.
Android
Step 1: Open the Play Store, search for the desired VPN, and click on the Install button.
Note: Here we are considering NordVPN as an example.
install vpn
Step 2: Then sign up and select a subscription plan that suits you.
sign up for vpn
Step 3: Connect to the country and its server you desire.
connect to the country
iPhone
If you have an iPhone and want to change the region through a VPN to access TikTok’s auto-scroll feature, go to the App Store. The rest of the steps are the same as those performed for Android phones.
3. Clear Cache
Cache overflow may sometimes result in poor performance or malfunctioning functionalities. If you’re having issues, such as the auto-scroll feature not working, you might want to try clearing the cache.
Android
Step 1: Open your TikTok account and click on the profile. There you will see three lines at the top-right corner of the page. Simply click on it.
o to profile
Step 2: Select the Settings and Privacy option.
select settings and privacy
Step 3: Go to the Cache and Cellular section and select the Free up space option.
free up space
Step 4: Click on the Clear option that appears next to the cache.
click on clear
Step 5: Next, you will be asked if you want to clear or cancel. Press the Clear option to clear the cache.
clear cache
 iPhone
Step 1: Navigate to your profile on your TikTok app, then tap on the three horizontal lines at the top right corner of the page.
navigate to profile
Step 2: Tap on the Settings and Privacy option.
choose settings and privacy
Step 3: Tap on the Free up space option from the Cache and Cellular section.
select free up space
Step 4: Press the Clear button that appears next to the Cache option.
select the clear button
Step 5: Again, click on the Clear button to clear all the cache data.
clear the cache
4. Reinstall the App
If upgrading the program and cleaning the cache doesn’t fix the issue, reinstalling TikTok could be the answer. Reinstalling the software can resolve a number of problems, such as missing functionality, by ensuring that all of its data is updated.
Android
Step 1: Navigate to the Play Store.
select play store
Step 2: Type TikTok on the search bar.
search for tiktok
Step 3: Click on the Uninstall option to delete the app from your Android phone.
delete tiktok
Step 4: Then, again, go to the Play Store, search for the TikTok app, and click on the Install option to get it on your Android phone.
Note- Restart your phone once the installation is completed to avoid any glitches.
 install tiktok
iPhone
To reinstall the TikTok app on your iPhone, you must first delete the old app from your phone. Here’s how to do this:
Step 1: Select and hold the TikTok icon on the home screen and click on the Delete App option from the pop-up menu.
delete tik tok app
Step 2: When the TikTok app is deleted, navigate to the App Store.
click on  app store
Step 3: Search TikTok using the search bar on your iPhone.
type tiktok
Step 4: Click on the Cloudy Blue button to install TikTok.
 click on blue button
Step 4: Once the installation is completed, click on the Open button to use the TikTok app, including the auto-scroll feature.
 open tik tok app
5. Contact TikTok Support
If the above solutions aren’t working, calling TikTok customer support is best. To make contact, follow the given steps:
Step 1: Go to your TikTok account and click on the three horizontal lines.
tap on three lines
Step 2: Navigate to the Settings and Privacy option.
Step 3: In the Support & About section, click on Report a Problem, then Submit a report that appears at the bottom of the page.
report a problem
Step 4:  Write your message here and click on the Submit button. The TikTok support team will assist you in resolving your query.
submit your feedback
2 Alternatives to Auto Scroll on TikTok
If these solutions don’t help, you can opt for these alternatives for auto-scrolling on TikTok.
1. Voice Commands for Auto Scroll on TikTok
Using voice commands can be a useful method for using TikTok more hands-free. Here is how to navigate TikTok using voice commands on Android or iPhone.
Using Voice Commands on Android for Auto Scrolling
Step 1: Install the Voice Access app on your phone.
install voice access app
Step 2: Then click on the Settings of your Android phone.
go to settings
Step 3: Choose the Accessibility option fromthe  settings.
click on accessibility
Step 4: Tap on the Downloaded apps or Installed apps within the Accessibility menu.
click on downloaded apps
Step 5: Click on the Voice Access option.
press voice access option
Step 6: Click on the toggle switch option to activate the voice access.
press use voice access
Step 7: Click on the OK button, which allows the Voice Access app to access your phone’s features.
click ok button
Step 8: Tap the Agree button to agree to the terms of service.
tap on agree button
Step 9: Click on the Continue button and Finish option to complete the setup.
Alt Text: click on continue
Step 10: Now, you will see a blue button on your screen, which is a voice access button. To activate voice access, click on it. When you open this app for the first time, you will be asked if you want to allow voice access to listen continuously or stop after 30 seconds. Then click on the radio option next to the app you prefer.
tap voice access app
Step 11: Open your TikTok app. To scroll hands-free, say “Scroll-down” to move to the next video and “Scroll-up” to move to the previous video.
open tik tok app
Using Voice Commands on iPhone/iPad for Auto Scrolling
iPhone/iPad users can get voice access for auto-scrolling on TikTok by following this guide.
Step 1: Open iPhone/iPad settings.
Step 2: Go to Accessibility.
tap on accessibility
Step 3: Click on the Voice Control option in the accessibility menu.
Alt Text: tap on voice control
Step 4: Tap on Voice Control to activate.
activate voice control
Step 5: Next, go to the Customize Commands option.
click customize commands option
Step 6: Tap on the Create New Command option.
create new command
Step 7: Type the word you want to use for hands-free in your TikTok account.
type scroll down
Step 8: Click on the Action button to move forward.
click the action option
Step 9: Select the Run Custom Gesture option.
run custom gesture
Step 10: Then swipe up on your screen and tap on the Save option.
save new gesture
Step 11: Click on the New Command option that appears in the upper-left corner.
tap on new command
Step 12: Click on the Application.
tap on application button
Step 13: Tap on TikTok for voice commands. Then, open TikTok and use the voice command for auto-scrolling.
open titok account
2. Try ClipGlider App for Auto Scroll
The ClipGlider app is used especially to maximize the speed of your videos to save you time. But recently it introduced an auto-scroll feature that allows you to scroll reels, TikTok videos, and other short videos hands-free. If you want to use the ClipGlider app for auto-scrolling, then you must check its pros and cons.
  • You can auto-scroll shorts and reels on your TikTok app with ease.
  • Offers window mode for Android phones.
  • Allows you to split screen while working with other apps on your mobile phone.
  • The step-by-step guide to set up this tool to auto-scroll the videos on your TikTok app is not properly mentioned, which can make your work a little difficult.
This app’s auto-scroll feature allows you to use it hands-free. However, as it is not accessible to every user, it can be a bit difficult to use. So, in this article, we have provided you with all the possible solutions to get the auto-scroll feature in your TikTok app and also shared alternatives for your convenience. We hope this article is useful for a hands-free experience.
Planning to create smoother and more engaging TikTok videos without hassle? A wireless lavalier microphone can significantly improve your audio quality, helping your content stand out and keep your audience engaged.
Q1. How to turn on auto scroll on TikTok 2024?
To turn on auto-scroll, navigate to Home >> For You Page. Then hold and press the video. Here you will see the ribbon menu where you can see the auto-scroll option. To activate this feature, click on it.
Q2. Why don’t I have an auto-scroll option on TikTok?
There can be reasons such as device variability, regional differences, gradual rollout, or any other technical glitches.
Q3. Did TikTok change scrolling?
Yes, the Auto Scroll feature was released by the company over a year ago, but it’s currently only accessible to a small number of customers before finally being made available to everyone. This is about killing doom scrolling.
Q4. How long before TikTok tells you to stop scrolling?
TikTok usually tells you to stop scrolling in between 60-90 minutes.
Q5. How to stop TikTok auto-scrolling?
To stop the TikTok auto-scroll feature, navigate to Home >> For Your Page. Then hold and press the video and click on the Manual Scroll option to disable the auto-scroll feature.
