How to Cascade Between the Solidcom C1 Pro and the FreeSpeak II?
March 27, 2023
Diagram:
① 4-wire interface on the Solidcom C1 Pro
② Standard network cable
③ 4-wire interface on the FreeSpeak II
Connection:
Connect the Solidcom C1 Pro to the FreeSpeak II through the 4-wire interface via a standard
network cable.
FreeSpeak II settings:
Solidcom C1 Pro settings:
Enter the Solidcom C1 Pro menu interface, choose 4 Wire Setting->line Sequence Switching,
and select Standard.
FAQ:
Question:
What should I do if I cannot hear the sound from either of the devices?
Answer:
Please check whether there are 4-wire options in the group. If not, you may not hear the sound from either of the devices.
RELATED POSTS
