Interface Connection & Installation introduction
March 27, 2023
OVERVIEWS: Mars 4k has rich interface, this article shows the usage of all the interface for your reference.
Transmitter Connection
No.StatusDetail
❶Mirrorless cameraSONY, Canon, Fujifilm, Nikon and others
❷CameraPanasonic, SONY
❸Professional video cameraARRI、RED、SONY
❹USB chargerThe charger must be 5V2.5A or above, 5V1A/2A power supply is insufficient, and device will not work properly
❺USB flash driveUpgrade via USB C flash drive / USB flash drive+ Type C  conversion
❻1/4 Cold shoeThe device can be mounted on the hot shoe mount of the camera
❼NP-F BatteryF970,F750,F550
❽D-Tap adapter cableAble to connected to V-Mount/G-Mount battery
❾12V DC adapterAll Mars Series wireless transmission DC adapters are common
Receiver Connection
No.StatusDetail
❶MonitorSmall or large monitor are supported
❷Switcher/directorBMD、SONY、Panasonic and other switchers are supported
❸Video capVideo capture card/encoderSupported by all capture cards
❻TripodThe receiver (RX) must be on tripod, at least 1.7 meters high, to avoid obstruction
Article Number: 【AS-220824001_6】
RELATED POSTS
