What are the Best Spotify Equalizer Settings for Airpods?
By Hollyland | August 28, 2024
You want to vibe on your favorite Spotify playlist, but when you pair your AirPods and start listening, something feels incomplete, right?
But is there anything you can do about it? Yes, been there, done that.
The good news is you can personalize the sound settings on Spotify and enjoy every bit of your songs.
All you need to do is customize your Equalizer, and that’s all it takes.
In this article, we will talk about the best Spotify equalizer settings for Airpods.
8 Ways to Master Spotify Equalizer Settings for Airpods
There are several ways you can adjust your sound settings as per your requirements; let us look at each one.
Adjust the Equalizer
Head over to settings and tap on the Equalizer option on the list. First of all, start with the Bass Booster and give it a slight increase of +2 to +4 dB. Avoid increasing the sound gradually, as it may lead to sound distortion.
Then, to improve the quality and clarity of vocals, set the “Spoken word” to a moderate level, usually +3 to +4 dB at once. After that, adjust the Loudness with a mild boost of +2 db.
Adjust all these settings slowly until you find a sound that meets your expectations. However, you may also refer to an Equalizer settings to begin with.
You can tweak the Deep Bass and Lower Bass to 60hz and 150 hz, respectively.
For lower midrange, keep the slider to 400hz. While Midrange and Upper Midrange should be kept to 1kHz and 2.5kHz, respectively.
To maintain the sparkle of the sound, 15kHz can be considered ideal.
Frequencies Based on Music Genres
Do all genres require the same frequency to sound good? Of course not. For instance, you may adore the natural qualities of instruments and vocals in acoustic music, but you’d prefer a heavy bass for heavy metal. Therefore, the following adjustments can improve the sound quality based on genres.
Rock and Metal:
  • Mid Frequencies (1-3 kHz): Increase to bring out the gritty tones of guitars and emphasize vocal clarity.
  • Low Frequencies (100-250 Hz): Slightly reduced to prevent the bass from overwhelming other elements.
Hip-Hop:
  • Low Frequencies (60-250 Hz): Boost to give the bass a deep, impactful presence that’s central to the genre.
  • Mid Frequencies (1-3 kHz): Enhance to ensure the vocals are clear and prominent.
R&B:
  • Low Frequencies (60-250 Hz): Boost for a rich, full-bodied bass that complements the smoothness of the genre.
  • Mid Frequencies (1-3 kHz): Elevate to keep the vocals sharp and well-defined.
Classical:
  • High Frequencies (4-6 kHz): Gently boost to highlight the intricate details and brilliance of orchestral instruments.
  • Low Frequencies (100-200 Hz): Maintain balance to preserve the natural warmth of the bass without muddying the overall sound.
Jazz:
  • High Frequencies (4-6 kHz): Slightly boost to enhance the clarity of cymbals and high notes from brass and woodwinds.
  • Low Frequencies (100-200 Hz): Keep balanced to ensure a rich yet clear bass presence, allowing the intricacies of the instruments to shine through.
Pop:
  • Mid-High Frequencies (2-4 kHz): Boost to make the vocals stand out and give the track a bright, energetic feel.
  • Low Frequencies (100-200 Hz): Lightly reduce to keep the bass clean and well-defined, ensuring it doesn’t overpower the rest of the mix.
Electronic:
  • Mid-High Frequencies (2-4 kHz): Increase to bring out the details in synths and vocal samples, adding brightness and clarity.
  • Low Frequencies (100-200 Hz): Reduce slightly to avoid a muddy bass that can obscure other elements in the mix.
Turn Off Active Noise Cancellation (ANC)
Background noise could be yet another reason you are not able to enjoy your favorite music or podcasts. To address this issue, you can resort to noise cancellation. Simply tap on the control center on your phone.
Wear both of your AirPods and touch and hold the volume button until the additional controls pop up.
From there, you can cancel the noise. And now, you are good to go.
Update AirPods
Did you know that Apple also releases firmware updates for the AirPods? These updates ensure that your audio processing, connectivity, and even sound quality meet quality standards.
Hence, you must ensure your AirPods are running on the latest firmware. To do that, tap on settings, click General > Software Update on your device and look for the pending updates. Updates for AirPods are installed automatically when your device is updated.
If you missed an update, tap “update” and wait for some time. After that, reconnect your AirPods and check the sound.
Experiment With Spatial Audio
This method generally best suits movies and podcasts, as it provides a cinematic sound experience with the content you watch. Working on this is quite easy.
Tap on the settings and click on the Bluetooth option.
There, you will find your AirPods’s name.
Click on that and turn on the personalized spatial audio.
This would enhance your audio quality up to a considerable level.
Adjust Audio Quality on Spotify
Another way to do this is by adjusting the audio quality on in-built options provided by Spotify. Understand that these settings are different for different devices. Since you are using an iPhone, you must follow the following steps for this:
  1. Swipe left on the Spotify interface and click on your profile picture.
  2. Head over to settings and privacy.
  3. Go to the “Playback” option.
  1. Click on Equalizer and toggle it to on.
  1. Now, you can drag the dots on the Equalizer to find the sound you like.
Note that these are the standard settings for the Spotify Equalizer; some advanced features are only available with pro versions of AirPods.
AirPods Vs. AirPods Pro Equalizers
Though equalizers are present in both AirPods and AirPods Pro, the pro version offers additional features such as Adaptive EQ. But what does this feature do?
This feature automatically tunes the music to the shape of your ears for a more personalized listening experience.
Further, ANC in AirPods Pro can alter the frequencies of certain sounds so that you can hear a clearer sound.
Troubleshoot Spotify
Sometimes, due to an older version of the Spotify app, you may feel the sound is not up to the mark. In some cases, it even takes a longer time to load because of the device’s performance issues.
Here’s how to troubleshoot some of the common problems while listening to your playlist on Spotify. Update the application first and restart your phone.
Clean up the cache memory to resolve issues related to corrupted data. If the problem persists, reinstall the application and reconnect your AirPods.
Tips for Best Music Listening Experience using AirPods
Apart from the above-mentioned ways, you can rely on a few tips to ensure a great listening experience every time. Let’s take a look at some of these tips.
  • Make sure that your AirPods are fully charged, as a low battery can lead to connectivity issues.
  • Disable conversation awareness while you are listening to music or any video on your device.
  • Poor fit AirPods can cause discomfort and sound leakage; therefore, an Ear Tip Fit Test should also be done.
  • Adjust tone volume as per your needs, and make sure the tone isn’t too high or low.
  • Try Apple’s silicone ear tips, as they can provide better sound quality and noise cancellation.
  • It is suggested to modify AirPod accessibility to make the AirPods more comfortable.
  • Troubleshoot AirPods issues, such as regularly updating firmware.
  • Always keep your AirPods protected in the case and clean them lightly before you use them.
That’s all for the best Spotify equalizer settings for AirPods, which will enhance your listening experience. You can now tweak the audio settings in a personalized manner for every song or video.
However, to get the most out of these tweaks, it is essential to follow the best practices as shared above. Last but not least, always ensure the AirPods are set at a controlled volume to avoid problems like headaches and hearing loss.
Optimizing your Spotify equalizer settings is an excellent way to elevate audio clarity, but capturing crystal-clear audio quality starts at your recording. A wireless lavalier microphone ensures pristine sound capture, offering exceptional audio clarity that’s perfect for music enthusiasts and creators alike.
What is the best AirPods frequency setting for Spotify?
Go for low-frequency bands, which are between 60Hz and 125Hz, on an equalizer to enhance bass and keep other aspects of the sound balanced.
How do you set the maximum bass for Spotify on AirPods?
It is simple. Go to Settings and then tap on Music. Click on EQ and click on the Bass Booster to enhance the bass.
How to set EQ for AirPods?
Access Equalizers from the “Sound” option in settings, and modify the sliders as per your requirements. Save these settings and then test the sound. If you need some improvements, you can adjust the sliders again.
How do I access Spotify equalizer settings?
Tap on your profile icon, Spotify, and go to Equalizer. Turn EQ on and then drag the dots on the EQ to get the sound you like.
